RCU Forums - View Single Post - engine causing glitching
Old 08-27-2005 | 06:02 AM
Dr Honda's Avatar
Dr Honda
Default RE: engine causing glitching
Hi,
3 words….
CHANGE YOUR SPARKPLUG!!
First of all… when a sparkplug gets old… it takes more power to fire it. A larger field is produced in the magneto, and more EM noise is made. Also… you want to use a resistor plug. A low value resistor will control current, and in turn… lowers the EM noise.
The stock Traxxas electronics will run fine in close proximity to a gas engine.
I’m still drinking my coffee… so give me a couple hours and I’ll look up the correct spark plug # for you.
Oh… BTW… NGK plugs seem to be the best in RC applications.
