RCU Forums - View Single Post - E-Starter Build help.
Old 08-27-2005 | 06:25 PM
Hellion179
Default E-Starter Build help.
Well, I went ahead and ordered everything..I got it all in earlier this week and started with the smaller stuff..only got to step 6 because I ran into some problems. I am supposed to attach the aileron linkages into the aileron slots(on the wing). It says in a note that the rod needs to be cut deep so torque rod is on aileron hinge line..So am I supposed to deepen the channels? Also, are the linkages supposed to just stab into the ailerons? How does that work? If you have built this plane I'd appreciate some help..so far I'm not impressed with a foam craft :P But then again I'm used to heli's... So thanks for all the help!
