RE: Next plane????
You are most certainly welcome there Mike.
I guess that would make sense, but if you are really tired with the electric version then the Superstar RTF is the way to go. Now, if you don't already you will have to get an electric starter (if you don't wanna start the engine with the finger.) I would invest in a starter. It will save your finger in the long run and you can use them forever. Also, you will need a power supply for the starter.
Also hope this helps....
~Michael~
