Let's start with the obvious...Are you peeling the backpaper off? If not, do so, it will adhere better. If you've done that then I think your iron is too hot. About 300 degrees or just above is where you want to be. Then don't leave the iron in one place too long. Keep it slowly moving.
Hope this helps.
Barry
