RCU Forums - View Single Post - 8 ft of bones! Sr Telemaster
Old 08-28-2005 | 10:24 AM
  #49
rryman's Avatar
rryman
Default RE: 8 ft of bones! Sr Telemaster
If you want to bolt on the wing to get rid of the ugly rubber bands, then bolting is the way to go. If you just don't like the nuisance of the rubber bands, try velcro straps. I've been using the same ones (4) for 3 years now on my SENIOR Telemaster. They are quick to put on and take off, and obviously don't need relacing often. But, you must use the right stuff. I got mine from Steve Herring at Vel-Tye. I was admittedly reluctant to try it at first, but he said if the wing came off, he would replace everything. Hasn't happened yet. It's sure a lot less trouble than rubber bands. He also has kits for attaching receivers and battery packs inside the planes that work well.
Randy
http://www.veltye.com
