RCU Forums - View Single Post - Eletric
Thread: Eletric
Old 08-28-2005 | 10:35 AM
RandyT
Default RE: Eletric
If you fly glow already then your choices are endless. It's more up to your dollar limit and amount of land. You probably can find a plane like the glow's you fly. A slowflyer like a Mountain Models Magpie or with the sports wing is a great plane. With a brushless outrunner and LiPo batteries, long flight times and quiet if you have neighbors near. 3D foamies like Shockflyers can be flown in your front yard again with an outrunner and LiPo's quiet. Prices will vary on the plane but most are fairly reasonable, $25 up to the sky, brushless motor combo's run in the neighborhood of a $100 plus or minus(depends also on the auw so this can double) a decent charger with LiPo capabilities 100+, then the batteries, this can really vary depending on power needs. Also you can fly with NiMh's, but LiPo's give you much better flight times and less weight. So you see it can really vary. Good luck.
