RE: gangs of servos buzzing
Dick--- Are you using a tiller arm/ bellcrank type setup to absorb the side load on the servos? If you like your rudder cables tuned anywhere above middle "C" that will help. Don mentioned loose cables that would do it too, then you dont have to wear out your expo generator.
