RCU Forums - View Single Post - what causes bad range check
Old 08-29-2005 | 05:33 PM
tsands
Default RE: what causes bad range check
thanks for the replys I'll probably check some things and maybe send it in. The line of sight was clear and the plane was on the ground. Plane was stored in a dry garage with all the rest of my stuff. Flew 2 others including maiden of pete n poke. They were fine. This is a fairly old setup should probably get a new set of batteries.
