RE: adjusting the needles.
So am I understanding you correctly that it is difficult to set the low end too lean because anything leaner than the optimal setting will result in the engine shutting off when the stick is advanced? I am having a little trouble figuring out my engine.
I am getting blubbering primarily after a downline. This would indicate a rich low end? I do not have any sagging on the upline.
