RCU Forums - View Single Post - Saito 82 RPM and Thrust Measurement
Old 08-29-2005 | 10:07 PM
seanychen's Avatar
seanychen
Default RE: Saito 82 RPM and Thrust Measurement
ORIGINAL: GarySS
Thanks seanychen! What was the size of the MA K series? Also do you have an APC 14x4W to try?
MA is 14x6.
I did try an APC 14x4W last year, and I recall it peaking at 10700 rpm. I think it pulls about 9.5 lb. ~ 10 lb. I no longer have a 14x4W to verify though.
I agree that mid-throttle thrust should be higher with the low-pitch wide prop. I find that while using higher pitch prop, I end up doing a lot of yo-yo-ing during hover, as I need to change throttle more for incremental increase of pull.
