RE: Nexstar RTF - Bank right
Also, check that the wings are level. I had the same problem after a minor crash (is there such a thing???) and had to shim the right wing so it was level with the left. Even if the plane looks ok after a crash, make sure you check everything! Even if you have not crashed, check everything.
