RE: Nexstar RTF - Bank right
shaharom, what you describe is fairly typical in trimming out a new plane. On the trim flight, use the transmitter trims to get the plane flying straight and level. When you get the plane back down, adjust the mechanical linkage the same way the trims did, and reset the trims to the center position. You may have to do more than one trim flight to get everything dialed in. Good luck with your flying.
