RCU Forums - View Single Post - CA v. Epoxy follow up
Old 10-25-2002 | 05:56 PM
Crashem
Default CA v. Epoxy follow up
Originally posted by xavier
The think that gets me is that the individual who made the recommendation has built many plains, is well respected and actually has designed and mass produced his own planes.
xavier,
I lot of "advice" people give you (including my own) is simply an opinion most likly based on what someone taught them. I learned to build when CA was new and not as widly used. (Titebond was recommend) I wasn't trying to worry you I simply like to be cautious especially if I spent a lot of times making the plane.
To be on the safe side you could just use more fiberglass to compensate for a possible weaker glue joint. Just remember don't go crazy since this will add weight.
good luck
