RCU Forums - View Single Post - "Gadjet"'s diesel conversion
Old 08-30-2005 | 10:35 AM
AndyW
Default RE: "Gadjet"'s diesel conversion
What if you made a head in which you could energize the element in a glow plug but at the same time adjust the compression once running. Might it be possible to eliminate or reduce drastically, (10%) the ether content or the ignition improver or both?
Or, what if you installed the filament from a glow plug into the contra piston in some way. Once started, would the element glow and would we get the same effect? I understand that heavy equipment diesel engines actually use a glow plug. Any merit to this idea? anyone tried it?
