CA v. Epoxy follow up
Hi Xavier after seeing your second post about glassing the center with CA,I change my opion about your plane.I've used the same method of wrapping the center w/glass then soaking the glass w/ ca,I cover my fingers w/ wax paper and rub the ca in, gives a fast and smooth finish. I've never had any problems,other than I don't use this method anymore the reaction of that much ca on me was bad,and the ca joint isn't as flexable as epoxy,your guru is probably right,just a different method.
