RCU Forums - View Single Post - Walkera Dragonfly #5 help
Old 08-30-2005 | 11:29 AM
woodymaxx's Avatar
woodymaxx
Default Walkera Dragonfly #5 help
Hello I recently got a Walker Dragonfly X-Rotation #5C V3 + Camo Fuselage and ran it a few times and now all of a sudden it shakes around when powering on the main rotors and in the air. I know this is because of something being unbalanced and started looking for it while using process of elimination. I found by taking the top rotor off, shaft and all, and powering on the lower rotors, the carbonfiber shaft above the lower rotor was wobbling pretty bad. I don't know if the shaft that powers the top rotor is bent too though? Is there anyway to fix this or should I try to get new parts? I have the part numbers in the manual, but where would you buy new parts for this particular copter? Any help would be much appreictiated! Thanks
