Zdz60: Is This Normal?
ROCK 114
No I haven't tryed any othe props other than an APC 22x10 which the rpm's came up a little, but I sure diidn't like the way it spooled up. real slow.
I've been mainly sorting out the props on my BME 2.7, with a 20x8 ZINGER PRO is the only one I can achieve a stable 7200 rpm and not overheat the engine. All the other inexpensive props keep the engine loaded at or around 6200 to 6400 except for the master air screw scmitar wooden props which give pretty close to the same rpm's. I just haven't flown with one yet.
The first chance I get to buy some other props for my 60 though, that fre@#$# sqaure thing is coming off!
It's real ffrusting trying to learn new stuff and you don't have much response after half throttle.
