RCU Forums - View Single Post - Sig LT-40 Build (maiden a success!!)
Old 08-30-2005 | 10:38 PM
  #108
figment
Default RE: Sig LT-40 Build
I was going to post earlier that getting plans copied at Kinkos was about $14 for two 36" x 48" sheets. But I am extremly annoyed now I had taken some measurements to compare the 2 sets and they looked okay, but apparently i should have measured greater distances. I just started framing up the first wing panel on my 4*60 on these crappy copies, and they are off by about 1/32" every 3-4". With the 4*60, everything is interlocking, so, I measured the part of the wing that I had layed out and then measured the original hanging on the wall, lo and behold it matches, grrrr. The other thing is that the plans don't seem to be consistently shrunk. The spars are right on the money, of course they are close enough that you might need a caliper to tell for sure.
Looks like I am going to have to wait some more to get anything done on this thing.
Anyhow, I would not asume that all copy shops are created equal, even among the same franchise, but I guess I will be going to Office Depot so I can get this build under way.
Be certain you check very carefully, lest you get stalled like me or worse, not realize till it is too late (Don't no how you could unless you were very careless).
Patrick
