RCU Forums - View Single Post - Poulan 25 from FL trimmer
Old 08-31-2005 | 01:11 PM
  #100
RysiuM's Avatar
RysiuM
Default RE: Poulan 25 from FL trimmer
ORIGINAL: diablo_r
I got hold of an APC 16x8 this evening, balanced it up and put it on the Poulan 25. It ran 8850 before it got too dark for my optical tacho to pick up the prop.
I can say ony WOW[8D].
ORIGINAL: diablo_r
Rysium, what glow plug are you using as I tried an OS type F and could not even get the engine to fire. I'm on straight petrol/oil as methanol is not so easy to get hold of over here.
As I recall, I hve OS F. The bottom of the glow plug is at the level ob the bottom of the gutted spark plug.
Do you have glow fuel (0% Nitro) available? You can mix that 50:50 with gasoline. You will have way to much oil but it doesn't hurt.
RysiuM
