RE: gas fuel with glo plug no ignition
Just as I thought.
A string trimmer would gain from added compression.
Because the chain saw comes in a higher state of tune, more compression, larger ports and more agressive timing
you are actually detuning it, lowering the compression, to deal with preignition.
You should also be able to adjust the timing, change grades of fuel or lessen the load to deal with preignition.
