RCU Forums - View Single Post - beginner question
Old 08-31-2005 | 03:37 PM
aeajr's Avatar
aeajr
Default RE: beginner question
Slide,
Here is my suggestion.
Assuming you have the space, I would suggest you spend a few extra $$ and get the T-Hawk. Since you don't have a local source of spare parts, etc, the fact that the T-hawk comes with two wings, two tails AND two batteries is valuable for you. Also has wheels and can take off from ground. the wing has a spar embedded in the foam which means you are less likely to over stress it. Comes with AC/DC battery charger which is very convenient. I think this is the best all around fit for you.
Second choice is the Easy Star. Being made of Elapor foam, it is very very rugged and you are not likely to need spares. It can really take punhishment. Add an extra battery for convenience. But no landing gear, so no rise off ground! Of course you could make your own. This comes with 72 MHZ radio in US. Is that frequency legal in your country?
Third choice, Aerobird. If you are going to order an Aerobird, which as landing gear, get an extra wing and tail as well as a second battery. That will add about $50. Factor these into the price since you can't go to the local hobby strore to buy spares where you live.
Make sure the available chargers will work on your power.
Good luck with whatever you do.
Based on your comments
