RCU Forums - View Single Post - adjusting the needles.
Old 08-31-2005 | 07:22 PM
Antique's Avatar
Antique
Default RE: adjusting the needles.
The low needle will not affect the high if both are set correctly...If you're not open at least a turn on the high the low is probably too rich....
That's why I always start 2 turns open on both and set the high first, then the low, then re check the high...Works every time on every gas carb....
