RE: Showtime CG?
The soldering iron trick works like magic!! The nut and screw came right out. I switched to the pull-pull, move the throttle servo forward, and changed out a JR811 to a HS81 on the throttle. HAving done that I was able to pull almost 7oz of nose weight out and close to an ounce for the servo swap. Shaved 8oz off the plane!
