RE: Hard time taking off
if you want to go through the trouble then 1st mechanically adjust your nose gear to track straight and true. 2nd while inflight trim your aircraft for straight and level flight, 3rd readjust nose gear to track straight and true. this should provide you with an aircraft that tracks straight on the ground as well as in the air.
