RCU Forums - View Single Post - bubbles in fuel
Old 09-01-2005 | 09:00 PM
downunder's Avatar
downunder
Default RE: bubbles in fuel
If the engine has a rear mounted needle valve then check to see if the bubbles only appear after the needle valve. If they're coming directly from the tank then check the fuel feed line for any splits or pin holes both inside and outside the tank. From what you've said there may be a split on the inside of the tank and when the level drops during flight it gets uncovered and draws air. If everything seems ok then it could be the fuel foaming from vibration. Make sure the tank is cushioned all around with foam padding and not touching any wood. If none of this helps then add one short squirt of Armorall to a gallon of fuel.
