robart hinge points
Hi I'm building a four star 60, I decided to use robart hinge points instead of CA hinges. My question is should I use the same locations marked on the plan, or can I move the hinges where there is more meat in the control surface? or should I add material in the specified locations?
My reason for the switch to hinge points is this is the preferred method for 1/4 scale and up planes....and this is where I eventualy want to go.
Regards
Mark
