RE: beginner
Find a local hobby shop or two or three. Walk in and ask what they have and suggest. Then ask why. I do believe, though more expensive obtaining your first airplane from a local shop is the best way to go. It gives you direct access to advise, suggestions, and help when needed. This is invaluble in the learning process and unless you know the guy next door will be there for you hold off on the mail order houses untill you get a little knowledge under your belt.
