Stingray!
Hi,
My Stingray just arrived! Well, it arrived a couple of hours ago, and I've been playing with it, then I remembered that I promised some pics.
It comes with:
--Aft fuse formers installed
--Main gear mounts installed
--Aluminum wing-spar receptacles installed on main spar former
--Carbon cloth lamintated between balsa sheeting and foam core
--Removeable fins, with carbon-sar receptacles installed
I also got a set of the new Yellow Aircraft retracts, and they look very nice. They look kinda like black SpringAirs, but they're harder, thicker, and they're air-up/air-down. Also, they're reverse-cylindered, so they'll work on the single Hornet or other sport jets. They're bored out to accept those 3/8" struts already, too. Those are $140 for a three-gear set, including all the doo-dads (tank, valve, lines, etc).
I guess my only wish is that the Stingray were a little bigger, but they built it at the time when the smaller engines were the craze. I'm planning to use a turned-down P-80 (for its light weight), but I'm also gonna build an interchangeable mount for .60-size pusher power (just to see how it flies on one).
Anyway, here're the pics!
