RE: PowerBox Sensor Switch Question
Give the guys at Duralite a call and ask them. If it works like many of the Li-Po battery management microchips on the market, the switch senses the present density of the charge in each pack and adjusts the current flowing into each pack for charge. There a several semi-conductor manufacturers that make the control chips for these type switches. I was surprised to find out that they are very inexpensive too. I hope this helps you.
Dan
