RCU Forums - View Single Post - Hydro R8
Thread: Hydro R8
Old 09-03-2005 | 05:20 PM
pompebled
Default RE: Hydro R8
Hi Rocco,
It's hard to say what the ampdraw will be, this depends on the boat set-up and propsize.
On our seven cell boats with surface piercing prop (36 0r 37,5K), the average ampdraw of the 8,4V 600 Race is 25 A with a 7-8 minute runtime.
As your boat has subsurface drive, be careful with a 37mm prop, in my experience it's too large and will fry the motor, no matter if it's a 540 or a 600 motor, check the temperature every two minutes, minimal!
If nothing gets too hot, run the boat with a full battery, flat out until the speed drops, measure the runtime.
Using the formula: 60 x battery capacity in A, devided by the runtime in minutes, you'll know the average ampdraw of your boat in that set-up.
If you take a look at the Graupner website (www.graupner.de) you can find data on all motors.
You can find a lot of info on how to make this hull really fast by going to www.rc-raceboats.de and use the search function ( "Suche" ) on "Trimmung", author: M3rl1n.
You'll find a long thread with a number of photos, showing how to go about it.
I added a few I have on my harddrive.
Regards, Jan.
ID:	319334   Click image for larger version
ID:	319335   Click image for larger version
