RCU Forums - View Single Post - Phoenix Giles 202 Elevator
Old 09-04-2005 | 08:33 AM
vern29
Default RE: Phoenix Giles 202 Elevator
A hint for getting the push rods in the holes. you can get some Oxygen tub that is for the nose and this will screw on to the end of your push rod. you just feed it from your back hole to the front of the plane and screw it on to the push rod then you just pull it threw and you have it in the holes with no problem.
