RCU Forums - View Single Post - Why NOT "Pattern"?
Old 11-03-2002 | 12:03 AM
  #111
rmh's Avatar
rmh
Default Why NOT "Pattern"?
I spent the day flying my 2x2 pattern model -equipped with ZDZ40 re-
It is cheaper to operate than any 140 setup-and costs less -
also italso has far more power - no needle valve fussing - a wooden 19x12 prop - it is quiet -
For those who really want a 2x2 mm plane that is easy to do and inexpensive and reliable - try this approach--If you have no idea as to what airframe to use - just copy the new Predator by JR Models - or any similar airframe .
Mine is std foam wings -and a light wooden fuselage - the only carbon fibre is the wing tube.
I have followed this thread from th start - almost all inputs have been on going back to smaller models to reduce costs and quite honestly - it is not necessary - and more to the point - not very attractive to many.
You don't have to believe it - but the quiet planes around here , are the gasoline models - with very few exceptions.
