RE: TC4 Spur Gear Mesh Adjustment? NOOB question
It's 48 pitch, but nevermind, I figured it out.
What happened, is that I had installed a FT Heat Sink before I put on my pinion gear. This kept me from moving the motor laterally without pre-adjusting the heat sink at the right angle. I had to take off the heat sink, figure out what angle the motor needed to be, then replace the heat sink.
Thanks anyway,
Master Blaster
