RE: dual elevator servo
there is a sub trim out of adjustment or the servos are not facing the same direction with the horns in the same direction.... also check in your dual rate setup area and make sure the numbers are the same between the 2 channels.(i had this problem once .. both channels should be the same in end point and dual rate throw
