RCU Forums - View Single Post - Showtime CG?
Thread: Showtime CG?
Old 09-04-2005 | 05:21 PM
pro2k
Default RE: Showtime CG?
When I did the pull-pull conversion I made it so the wire were taunt in the nuetral position. When you give it full left or right input there is quite a bit of slack on the non-pulling side. IS this normal or do you want to keep it fairly tight throghout the motion? How do you correct this? Is it because I used to short of an arm for how far the horns are screwed out on the tail control threaded rod?
