Glueing With CA
I have a fundamental question regarding gluing parts together using CA glues. Using building a wing as an example, do you just tack everything together, remove it from the building board, then go back and glue every joint? Or do you glue all the joints while it is still on the building board? I've found that if I glue ever joint while it is still on the board, I tend to over glue the ribs to the spar resting on the plans. This makes it difficult to sand that side of the wing.
Chuck
