RCU Forums - View Single Post - servo troubles....
Old 09-05-2005 | 12:34 PM
Campy's Avatar
Campy
Default RE: servo troubles....
CA a piece of dowel in the hole. When the CA is dry sand any dowel sticking up even with the servo tray, then drill a 1/16" hole for the screw. Put the screw in, then take it out and put a drop of thin CA in the screw hole. When the CA dries install your servo. The CA will harden the threads made by the screw.
A tip for you:
RTL Fastners has socket head servo screws with a built in washer. They use a 5/64" ball driver. Much easier to install than the philips head or slot head screws.
