RCU Forums - View Single Post - CA Hinge Material
Old 10-27-2002 | 03:55 AM
Steve Guinn
Default CA Hinge Material
NOT a no no. Install hinges in both surfaces and then put 5 or 6 drops of thin CA on each side. Makes no difference if you put vaseline in center. CA wicks through entire hinge through capillary action.
P.S. Seems to me the vaseline would interfere with the CA being absorbed by the hinge and you would end up with a weak bond.
