Engine mounting on a Sig SE; please advise
I have a 46 fx in mine and have had no problems so far with fuel starvation. I see what you're saying, my carb is about an inch above the centerline. I have mine mounted so that the little supports on the engine mount are facing up as you can barely see in the manual. I did not have to cut for the muffler but I did have to cut a small notch for the remote needle valve.
