RCU Forums - View Single Post - TOC 30% YAK Almost Done!!!
Old 09-06-2005 | 06:21 PM
Banche
Default TOC 30% YAK Almost Done!!!
Well it’s been 4 months now but I am nearing completion!!
The plane's build is awesome. I don’t like the aluminum landing gear and tubes, which seem just a little weak The hardware is like for a 90 size plane but and my 5 year old brother could break that plastic but Everything else is awesome......I guess that just leaves the plane ( spinner is like 6oz+ big heavy aluminum, the controle horns and all the clevises and connectors and rods are crap, the fuel tank is no bigger than the one in my F90 and it seems junky for a plane of this quality) If you don’t care about that though then well... think again.... On to the good
I love the covering and the whole build. There are hardly any wrinkles after 4 months at my house and the small things that peeled off I have easily fixed. No damage whatsoever in shipping. Everything, especially the canopy, is built pretty light and the whole plane seems especially strong. The only thing on the plane that is a little weak is the firewall board itself. That is easily fixed though. If you have built like a say.. funtana 40 or 90 you can build this plane. You can get 70 degrees of through out of the ailerons and elevator, they are big, and the rudder looks like a BEAST! You need torqy servos though. I would of loved to get 5955's for everything but$$$$. You can probably do 50+ degrees of through without stressing the 5645's too much.
I have a DA-50(stock muffler 23x8 NX Pete Model Carbon fiber spinner and a 16oz tank) and 4 5645's and 1 5955 for the rudder. I have 2 2cell TBM Li-ions and a 3cell pack. All are on MPi regs and I have one JR HD charge switch.
Hardware: I have SWB arms and carbon fiber pushrods from chief. I also have cactus aviation blue anodized control horns. I used Kevlar cable for the rudder pull pull. My control setup is slick!
I have No $ right now But I will soon get a 9303 and a 9 channel pcm receiver. I will also get a smoke pump and another battery for it.
I also need to get 2 digital minis for the choke and throttle.
I could of used the hardware and cheaper servos and saved $$$ but I want this plane to be built PERFECT!!! I think it is gonna fly awesome from what others have said.
I weighed the plane and it came in at 14.6 lbs. The only things that were not in it were the fuel tank and smoke tank and pump, receiver, probably 2 extensions and the titanium aileron links. Oh yah and the 3 cell Li-ion and the regulator. I think it will be 16lbs- when all is done.
People say it flys light at 18lbs. I heard a guy on here say it flew awesome and had great power with a DA 50. I say Mine will Fly awesome too. Maybe I can give you guys a report and hopefully a vid( If I can convince my parents to get a new camera) in the near future.
I couldn’t load the pics on this post for some reason and all my typing got deleted once so I am gonna post pics in like 30 seconds if I can
