RCU Forums - View Single Post - magnum .91 4 stroke advice needed
Old 09-07-2005 | 08:27 AM
mirwin's Avatar
mirwin
Default RE: magnum .91 4 stroke advice needed
ORIGINAL: danieldrake
Final question.
3. How are you guys getting the after-run oil into the crank-case, the carb intake is the only thing open.
Some will tell you that the after-run oil will disolve the O-ring in the carb and others will probably say "nonsense." I don't want to take that chance, so I remove the glow plug, and put it in that way.
Mike
