RCU Forums - View Single Post - Need Help with Sig Senior ARF
Old 10-27-2002 | 12:16 PM
Scorpionjack's Avatar
Scorpionjack
Default Need Help with Sig Senior ARF
Who said anything about ballooning?
The Senior is an excellent flying aircraft. As you mentioned the right engine! Balance without added balast is the key to a light aircraft with years of use ahead. The Saito 72 weighs 16.5910 Oz's, the ASP 65 weigh's 23.125 Oz's, OS 91 weighs 24.250 Oz. (These are 4 Stroke)
Your 2 stroke: OS 65 LA weighs 18.9 Oz's. With the weight difference you would have had to add wieght.
There is way's to set it up with a lighter motor without using balast. But that would require a C-cell Rcvr pack under the tank and using mini BB servo's on the control surfaces (i.e. Hitec 225BB style servo's) Instead of full size servo's and a larger weight disp Engine. With the size of the control surfaces on this aircraft. I personally wouldn't want to trust a recovery to something that small.
