RE: Muffler Seal?
I use clear or white (depending on what's open) silicone sealant after wiping surfaces with acetone. J-B Weld will work, but could "weep" if there is enough vibration and a poor clean-up job prior, and if you ever do want the pieces apart you're S.O.L. Any liquid "gasket eliminator" compound will do. It's a non critical application.
