MARK.
You can get the cf pushrods and h9 links( I think they are 2'') and other things like ball links. I used clevises on the elevator's though, whatever works for u.
http://www.chiefaircraft.com/cgi-bin...cessories.html
DRUMBUM. I got the kevlar cable, 4 h9 1/2'' titanium links and clevises from ...
http://www.troybuiltmodels.com/GHardwarePull.htm
I am sure the swb turminators would work a little better. Kevlar gives no interference, 24' for like $3 and it is much easier to install, like alot easier!!! wow it was soooo easy. Just loop around pull tight with you finger and ca. then do it to the other side and turn the clevises and ball links to tighten it, and heatshrink so it doesnt come loose, but I dont think mine would of broke without heatshrink anyways
