RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 09-07-2005 | 10:10 PM
  #682
NuKA
Default RE: E-FLIGHT BLADE CP
ORIGINAL: upperkingjr
You sure your connectors for the servos are hooked correctly? pull the plugs out of the receiver for the two motors and then turn the chopper on then look at one of the blades or tip from the side, give the transmitter throttle and make sure the tip of the blade twists clockwise.
Transmitter to chopper test.
Put the tail of the chopper pointed towards you.
Left transmitter stick test :
Push stick left = servo on the rear right pushes up servo on the rear left pulls down.
Push stick right = servo on the rear right pulls down servo on the rear left pushes up.
Push stick up = servo on the front pulls down and both servos on the rear left and right push up.
Push stick down = servos on the rear left and right pull down and the servo on the front pushes up.
Right transmitter stick test :
Push right = tail motor will push the tail to the left.
Push right = tail motor will push the tail to the right.
Push up = the rotor blades twist clock wise and the chopper motor revs up for lift.
Push down = rotor blades twist back to center or an even plane and motor slows down to off.
Hope I didn’t give to much info:
yep, all that checks out, well, aside from the tail, i have the remote reversed so that with the tail in, left moves the tail left, and vise versa,
thanks for the suggestion tho, im going to go check evereything over again, and replace the flybar and make sure evereything is snug where it is suposto be, im still thinking i have my picth out a bit on one blade, (i have set the tracking on the blades) so, keep checking it over and over, i know i missed somthing somewhere
thanks again
