RE: 14MZ: Flying wing 2 aileron programming question
WHAT???
That is not correct Bax!
Now I have given the correct answer to this question two times, but got the messages deleted. I got this PM explaining why it takes time before Futaba answer your question: We look at the different questions and then formulate answers. We cannot get to them all right away. Sometimes we have to check the operation so that the answer is correct.
That really is a fair that you Futaba guys take your time to be sure you give a correct answer, but now you are giving this guy a wrong answer? Scary!
To get 100% elevator-throw on the setup you mention you have to edit the values in page 2 of the Elevator to Camber mix screen! These are default 50%, and have to be increased to 100% if you want the same throw on the elevators as ailerons. THEN you can adjust the AFR to suit your application as you suggest!
OAK
