RE: From ATX to MT (need some tip!)
If you get the clutch bell I mentioned it will come with the pinion gears already on it. The spur gears (the big red ones) are the same for both the ATX and the MT2.
I forgot to add the only difference in the shock towers is that the ATX has the center cut out to mount the buggy body.
rolland
