RE: Showtime for Pattern flying?
Thanks Don,
As I wrote, I tried to reconstruct one of the ailerons as much as I could. Have glued everything on now, I hope it flies ok, if it needs a lot of trimming I will tear the covering material underneath and fix both ailerons where warp exists. I also found some warp on the left stabiliser, balsa was probably cracked. I fixed that too.
I'm not very sure about these CA hinges, I think I'm going to put some pins to the external hinges plus some monokote to seal the hinge gaps.
Hope it flies ok, I will probably participate at a local pattern contest in October, but there's not much time as I have to break in my YS-110, set up the plane and practice.
I will definatelly use your throws and expo for pattern, what prop would you recommend for pattern and the YS-110? Is a 16x6 ok you think?
Regards,
Nick
