RE: xb8 SETUP SHEET
I find that leaving the rear shocks off the towers helps to prevent the back end bouncing up all the time on that dodgy surface.
They actually go on the top outboard hole, so you'll need to put the dot on yourself. I cant be doing everything for you people.
