RCU Forums - View Single Post - The new Lanier Edge 87"
Old 09-09-2005 | 06:23 PM
Banche
Default RE: The new Lanier Edge 87"
Really? I think that the wing area and span is right on with everything else out there but other than that[:'(]
Compared to all the other planes out there it is like 2lbs overweight. Not to mention every other plane has only 1 aileron servo. You should only need one and if you need 2 the aileron is probably weak and if they build the aileron weak what about the rest of the plane?
Coming in at 16 1/2lbs is still a little bit heavy for the wing area and with a DA50 wich is probably what you need for that weight, it would probably be just a little underpowered. Lanier hasnt built any good light 3d ships like TOC Or EF or BME or Carden Or aeroworks ....
but maybe I am rong or maybe you just want to fly IMAC but $100 more is well worth it for a plane that is just as bbig and 2lbs lighter.
